Wanna get 300 hp. Suggestions?
Nevyn04
Glad to hear I don't need to worry about close gears. But will a stage 3 clutch be good for daily driving? I was told stage 2 was most you wanna do for street use.
Trekk
If you get an unsprung clutch, that is when its annoying as a daily driver.
jhar_EK
word
check out clutchmaters.....they make a full disc stage 4 i think...a little better on the dd side of driveability than a 3 puck or 6 puck
Just a honda!!
I dialy drove my exeddy 3 puck just feather it out u will learn
Sent from tapataalllkk
Nevyn04
Ok. So I found an OBX LSD for almost 500 bucks. Seems they are between 500-1000 dollars. Also looking at clutchmasters FX300 clutch. It's not a full disk clutch. But it is sprung.
Suggestions on cams? Or tips selcting cams? Do I need longer ehaust duration than intake for boosted engine?
TokyoSkies
Boost Junkie
I personally don't trust OBX. I'd go with a Quaiffe LSD. It's a bit pricier, but you'll be happier in the end. If you're going to boost, you could save yourself some cash by picking up an LS trans (if you're B-Series that is), rebuilding it, and fitting it with a Quaiffe. The gears are naturally a bit longer, and fifth has a nice final drive ratio that is good for DD. As far as clutches, never used Clutchmasters. I had an Exedy Stage 2 Ceramitallic clutch, and a 8.5lb flywheel for DD, and it was kinda stiff, but easy to get used to. It killed in stop and go traffic, but damn did that clutch grab like Bruce Lee haha. I wouldn't recommend a lightened flywheel. Just have the stock flywheel knife-edged and polished. The added weight will help you control throttle response when driving around town and wanting to lay low. Damn car would boost hard all the time with that flywheel haha.
As far as cams, yes you'll want cams with a longer exhaust duration. The longer the exhaust lobes, the better response you'll get (i.e. minimize turbo lag). I hope I worded that right haha.
Nevyn04
Ok. So trying to identify my SC and determine stock boost and CFM and this is what I found.
[/IMG]
So does that mean this is a magnuson SC with a Jackson Racing intake manifold? Can't find info anywhere.
Also, would the longer exhaust be good for a SC? No boost lag to worry about right?
TokyoSkies
Boost Junkie
[/IMG]
I'm dumb, and obviously didn't read enough of your post lol. I didn't notice you were SC'd.
I can't tell from that pic what I'm looking at. I'd assume that is the top-backside of your SC or something.
As far as cams, yeah you don't have to worry about boost lag. I'm not really experienced with building for SC in all honesty.
Nevyn04
Lol. That is the top backside of the sc. Those are the only identifying marks on it other than the intake manifold which clearly says jackson racing. The closest jackson racing sc I found that resembles mine is th M62. But why does it say magnuson on the sc with a barcode. Can't find much info on it. Possibly because its outdated?
Trekk
Magnuson pretty much makes most of the superchargers. People just have a kit made up and slap their name on it. You need to find out what size pulley is on it or just add a boost gauge if you don't have one. Stock is like 5-6psi.
Jersey8
B20: Detroit Muscle!
i have a used quaife LSD if you're interested...
Nevyn04
I don't have a boost guage though i would like to get one installed. I can check the size of the pulley but in earlier posts I was told CFM is what i need to worry about and not PSI. I know I can buy a smaller pulley to increase PSI but this will only work to a certain extent. By comparing pictures of common SC's it looks like an Eaton M62. Though can't be 100% sure.
sohclubkid
Sick 6/6
it makes 52HP and 40TQ on the stock numbers...
you will want to go turbo if you are looking for 300HP daily setup
Nevyn04
Can I get a smaller pulley and bump that number up a bit? And if I increase compression? Maybe get 70 hp out of it?
Nevyn04
Found a set of Wiseco pistons and eagle rods with ARP crank bolts for $800. This will increase compression to 11.5:1 from 10:1. With a smaller pulley puttin my SC at 10 psi and a proper tune wouldn't this push my power up a pretty good deal?
Nevyn04
Ok. Did a lot of research on increasing compression while under boost and it doesn't seem like that good of an idea. So i'm juggling the turbo idea. The Speed shop in my town offers an STS turbo system installed for $6595. Is this a good price for a full set up installed?
ZeroMech63
$6500 for 300HP??? Hell no... I cant see more then 4k n thats with a new oil n water pump tune n on the street
