SCHMIDTY's 95 Civic
Wreckless Hype
¯\_(ツ)_/¯
Probably not a whole lot that you'd notice, and that's assuming it was done correct. Swap a GSR or something nice in there :cool:
SCHMIDTY
That will eventually be my plans is to boost it...so for the d series thing...what do the three letters and numbers mean after the d
Sent from my SAMSUNG-SGH-I537 using Tapatalk
buzzbombtom
captin sleep0
only you can tell me that ;) on the left side of the motor block there is a stamp that will say d15... tell me what that says and you will also tell yourself what it is. the head is off a different motor, without getting too confusing that is what motor you have
SCHMIDTY
Ok well now I'm confused because in the original ad the guy said it had a d16z6 motor??
buzzbombtom
captin sleep0
it could have been swapped go look and tell me what letter/number combo is on the block
Honda9206
Working on the 92 DX
I guess the only way is to look at the engine. The z6 is a common swap in 5th gens so I would say its possible.
Sent from my Galaxy Nexus using Tapatalk
SCHMIDTY
Ok I'll look when I can...is the z6 a better engine?
SCHMIDTY
Woo!!! Ok so if it did have that swap...would that mean it in fact does have a vtec?
Honda9206
If it has a d16z6 then yes it does mean VTEC
SCHMIDTY
Ok thanks for all the help guys! I'll let y'all now what it is when I can
Honda9206
It looks like you have an ex so more than likely you have a z6.
SCHMIDTY
So I went and looked and it is a d16z6...I talked to the previous owner and he said it was rebuilt a while ago...is there any way I can check and make sure it really was rebuilt??
Wreckless Hype
¯\_(ツ)_/¯
Not really. I mean, you can do a compression and leak down test on it. Aside from that, if it's not leaking oil, coolant, or grinding gears, it can't be in TOO bad of shape.
SCHMIDTY
Ok well I'm not too worried...the engine runs strong so its all good
SCHMIDTY
Finally got a new job!!! Gonna make 18 an hour=) now just gotta wait a couple weeks:(
